From all my research everyone says to stay away from any intake that keeps the filter inside the engine bay. The intake air temp will rise and you will LOSE power. The car actually has a somewhat cold air intake already, as the entrance is above the radiator and it's pulling air from outside. What I did was install Z1 true cold air intakes made for the g37/370z. Cut holes in the radiator support using a circular sheetrock saw blade attached to a regular drill. You don't even have to remove the bumper, just the front grille to gain access.
