Issue with seat fan after dome LED light install
nima
2010 FX50S
I replaced the map/dome lights for both driver and passengers. Installed a 5k 194 type 4 SMT LED. Looked pretty bright and thought I'd keep it. Then I noticed the driver seat fan is acting up (when set to cool, didnt try the heat). The fan would start up when I turn on the ignition as it always had, but then after 1minute 12 seconds (yes I timed it 3 times) the light indicator on the nob would go off and the fan would stop working. I would then have to turn off the car completely and start it back up before the fan would work again. I've had the car for some 5yrs now and never had an issue, it only emerged following replacing the bulbs with LEDs.
So I switched back to OE bulbs and the problem went away. Now I'm thinking twice about replacing all the interior lights with LEDs. This pair was purchased from VLED as per the link below (no I'm not affiliated with them or any other manufacturer/distributor).
[Dead Link Removed]
I'm no electronics expert, just have some wrenching experience and basic understanding of electronics to get me by; but I think the circuit for those bulbs and the seat fan maybe the same/shared, and because the LEDs have a different power draw it could be causing the issue.
Has anyone else experienced this? What do you think could be causing this (apart from the obvious LEDs being plugged in)?
I just installed LEDs in my interior, so far no problems. I had the seat fans all the up today: no problems. I forget where I purchased LEDs from. They were for my other car.
My guess is you might have gotten a deffective bulb causing excessive draw from the circuit. You could get a multimeter & check ohms reistance on every bulb you received to see wich ones the culprit.
So I'm trying to remember some grade 5 science.. resistance = volts/current, 14.5/2=7.25 ohms. (As per the specs on their website)
Spoke too soon.. the problem seems to continue even after having the OE bulbs back in there.. the seat climate control dial's light goes off after a little while and the fan stops working. The only way to get it working again is to turn the ignition off completely and start it again. any ideas?
