What's up guys I'm looking into getting an invidia n1 exhaust of the 350z. Mid pipe and muffler only. Would it work with little or no modification. single path exhaust
pretty sure it will work if its just a single piped system to the muffler. just need tips extended and a extender piece between the y pipe and mid pipe
as viperi said, very possible with the G35 extender and HR design 3" y-pipe. getting the canisters to fit and extending the tips will be challenging , I would think.
if it all fails, could be an expensive lesson. good luck.
You could ask Gordon his opinion, as the Invidia rep he might have some valid information. The flat lying pipes in front of the muffler don't look promising. Most of the FX pipes have a couple of bends to run over and around the axle and sway bar.
I thought stu got the motordyne shockwaves? The issue I see with this one is that the tips will be hard to extend. The other cannister exhausts have tips that are larger than the piping. So you can just cut the piping and extend. With this one, you would have to find a pipe that matches the diameter of the tip which would be hard. Or you would have to move the entire cannister which would be tricky.
Extending the tips shouldn't be that hard. Canister fitting shouldn't be a problem I had the hks rep from the 350z I got it to fit and those canisters were huge too
