Invidia exhaust install.
illestFX35
Los Angeles/Glendale
2010 FX35 RWD
Hey i am trying to install my exhaust syatem and i encountered a couple of problems with removing the exhaust out.
1. A bolt that connects the muffler to the second pipe turned into a circle because it was tied in so hard.
2. The first pipe with the cat has a bolt that I will have to break because of the same reason but there is a huge muffler or pipe that blocks the bolt from coming out. Do I use the stock bolt?
I will add pictures thanks!
You can cut both bolts to remove them. On my 1st gen, they had to cut the mid pipe because the flange to the muffler was stuck together, the bolt would not loosen and instead bent so they cut it off. You can replace them with I believe M12 nuts and bolts. Just make sure they're stainless otherwise you'll have more corrosion issues if you try to remove in the future.
