Interior re-wrap.
Dave, I guess I could do it:) I never thought of making a separate DIY just for the radio bezel. In a nutshell, you have to remove the board that's screwed to the bezel, 6 screws, you can also take off the aluminum accent bar above the nav screen and the side wants 4 screws each. Then just apply the vinyl and slowly begin to cut the holes for the knobs, CD, and other buttons that go in. You don't really want to wrap it inside and around, it will make it too tight for some of the buttons to function smoothly. the vents you can roll behind. with a sharp scalpel you can also cut out the little squares for the vents symbols if you care, and then just reinstall it all back:)
