How to reset oil maintenance notification
Mr Remarkable
Dallas
I just bought a 2005 FX35 a couple of months ago and now it's time for an oil change. This is my first oil change on a FX35 so I don't know how to reset the oil maint. notification. Any input will be greatly appreciated, thanks.
You just have to push the "reset" tab on the screen but the FX has to be parked/stopped. It is also in the owners manual.
I must have overlooked it, thanks
---------- Post added at 07:30 AM ---------- Previous post was at 07:28 AM ----------
Wtf, man. EMN
---------- Post added at 07:35 AM ---------- Previous post was at 07:30 AM ----------
Is this for touchscreen application? Because mine isn't.
Wtf, man. EMN
There are no OEM touchscreen applications for the FX. And I don't know what EMN means, but they're right - you should always read the manual to a car you figure will be driving you from place to place. Just makes sense.
Here's the manual just in case you don't have a print copy:
http://www.infiniti-techinfo.com/refgh0v/og/infiniti/fx/2006-Infiniti-FX4535.pdf
Don't worry that it's an 06 - the 05 wasn't loading properly. 06 will do.
Regardless, I'll help you out - this is what you do:
1. Figure out if you have navigation or non-navigation
If you have non-navigation:
1. Press the "maint" button (middle button on the right cluster of gel-like buttons below your screen)
2. Using the wheel in the middle of the headunit click into engine oil (press the little circle in the middle of the wheel)
3. Turn the wheel exactly one click to the right (clockwise)
4. Press the little circle in the middle of the wheel again
If you have naviation:
1. Press the "trip" button (middle button on the right cluster of gel-like buttons below your screen)
2. If your maintenance notice pops up at this point, you need to press the trip button 4 more times. Otherwise, press it 3 more times.
3. Using the wheel in the middle of the headunit click into engine oil (press the little circle in the middle of the wheel)
4. Turn the wheel exactly one click to the right (clockwise)
5. Press the little circle in the middle of the wheel again
And that's all there is to it. Check the manual though, I think it explains it in less steps :tongue (2):
P.S.
My guess is EMN means eat my nuts.. which is not a nice thing to say.
