How to remove the top antenna
MB2702
san diego
I have a 1 gen and am going to vinyl my roof and am wondering if anyone knows how to remove the top antenna? Also if it is hard to do? thanks for all your help!
replacing 06fx Antenna
hi, my 06 fx antenna broke. its mounted on the front so i figure its the same as 04fx. from reading above post, there is a bolt from the inside but does the headliner can be pop easy? am scared i might break it or how do you get into the bolt part of the antenna from the inside. please need you help. thank you :(
If you follow the link, it shows that you don't need to remove the headliner. You can access it from the sunglass holder area. But I'm not sure about just pulling it down. If you do want to remove the entire headliner, it's not hard but it takes forever. You have to remove the A, B, and C pillars as well as most of the panels in the hatch. They all sort of interlock back there, so you can't access the headliner without taking them out.
