Helppppppppp!!!!!!!!!!
kylehoang
US
i had a FX35 04 with 6k headlight, i try to upgrade with 10k and i bought the set 10k on ebay it came with a ballast. i took three audio shops, they couldn't do it. can anybody give me a suggestion?????
you need a d2s bulb in 10k, then it just replaces the oe bulb... an aftermarket whole kit won't work without butchering it & for no good reason, it's easier to use the correct bulb than an aftermarket kit...
At least somebody knew what he was talking about . . . call me dumb . . . or rather to lazy to decipher the code. ESL?
bro... i had change the bulbs only the bulbs type are D2S, just change the bulb not the entire system. leave the original bundled ballast.
the ballast aftermarket are not so good in terms in quality and performance.
believe me.
yes turbocad is correct. Please read/ search through some of the threads here before doing upgrades. Since most here have gone through the trial and error phase or some just have the knowledge to do it right the first time.
Hopefully they can refund your money, if not, you can use them on your fog lights (see my signature below for a how 2)
