HELP ME ASAP....Filter
Krayzie
Aérospatiale
Vancouver, BC
ok, so i cleaned my filter last night and now i cant find the box it came in, so have no idea how much to oil it. Its the K&N that came with the LMS intake
http://www.knfilters.com/cleaning.htm
4. OILING (SEE FIGURE 3) ​
RECOMMENDATION: FOR BEST RESULTS USE K&N AIR FILTER OIL.​
Apply K&N Air Filter Oil liberally to the dirty side of the filter only. This will allow for a visual reference of complete coverage.​
A. If using a K&N squeeze bottle, squeeze bead of oil along the crown of each pleat using the lip on the squeeze bottle tip as a guide. Utilize graduated view strip on bottle to dispense proper amount of oil.​
B. If using a K&N aerosol spray, spray an even amount of oil along the crown of each pleat.​
Wait 20 minutes for the oil to be absorbed into the filter media. Inspect the clean side of the filter for any areas that are lighter in color. Touch up these areas in the media by applying oil to the dirty side of the filter. Continue oiling procedure until there is an even red color over the entire surface of the clean and dirty side of filter.​
It is important not to over oil the filter. If it is soaked to the point where oil will come off and sucked into the intake, it can mess with your MAF sensor and throw a SES light.
