Spray some liquid wrench and let it soak for a while then hit it all over the area around the surface where the rotor mates to the hub then if it's still stuck repeat the liquid wrench soak wait 5 minutes and hit it again repeat as often as it takes and it will come off.
NOTE: A Steel hammer will work better to loosen the rust.
