Handle came off door, need help
909FX
Premium Member
Premium
FONTANA, CA
2010 Honda Crosstour
So yesterday I went to open my driver side door to my FX and my handle came off. Not sure if someone messed with it or if it's just normal wear and tear. I need to find a new handle and need to see if anyone has a DIY on this.
Any help would be greatly appreciated.
Thanks in advance.
///1196
This should get you started.
once the escutcheon part is removed grab the handle and slide it to ward the hole where the escutheon is and it will pull right out, install will just be the reversal.
do you still have the handle? if so I have a spare handle but you would need to transfer the gasket and small black plastic cap from you handle ,I have thoes parts but they are not in the best shape because the went into the chemicals when I had the chrome removed from my other set.
///1196
hey, whats up? Yeah, my handle support brackets broke. I don't know if someone tried breaking into my FX or what. But it just came off and the tabs are broken. How much do you want for your handle? Hit me up on private message.
Thanks
