H&R Trak+ DRS Spacers - Not-so-helpful H&R call, perhaps I can solicit help here?
cheste1
Maryland
2011 FX50S
Chuck
In a an attempt at getting proper extended stud sizing for the 20mm H&R Trak+ DRS spacers I had just purchased last week here on the forum, I decided to contact H&R directly to see if I could source the actual stud part# and details. The call did not go well mainly due to the rep taking an adamant stance on not supporting these spacers on the FX (09+) vehicles. Ultimately, the rep came back and told me that the part # that ships with this set is #12255024. However, upon looking this up, it does not appear that it is the correct size stud for the application as it appears to be the same size as the actual OEM studs.
Long story short, the H&R rep told me that they will not support the use of these spacers on this model vehicle.
I am confident that they will work regardless (many of you already run these on the late model FXs) and I have a feeling that the extended studs of the 45mm thread-length variety may work just fine (M12 x 1.25, 68mm total length). Here's an example of such a part on eBay: http://www.ebay.com/itm/45mm-EXTEND...Parts_Accessories&hash=item27d42a272b&vxp=mtr
Is this a correct assumption that these 45mm extended length studs will fit my application without any further need to 'cut down'? For those that have the H&R Trak+ DRS 20mm spacers, do you know the length of the extended studs that came with the kit?
Thanks for the help in advance!
Sorry didn't notice that you have a second gen. Not sure if the measurements are the same
