Hi Mark,
Thanks for posting. Here is my feedback.
1) Progressive Spring Rate
2) H&R drop is 1.3" front, 1.2" rear. Eibach is 1.2" front and rear. Intrax is 1.8" front and rear.
For GT Spec springs,
I suggest 1.5" front and rear drop. You will be close to the limit of safely using the OEM Struts/Shocks without dramatically shortening the life of them. Intrax is too much of a drop for stock struts/shocks as you will probably bottom out, and your alignment will be out of OEM specs.
Also, anything around 1.3" and 1.2" drop, you will have competition from H&R and Eibach. Drop farther than 1.5", you will have competition with Megan and BC Coil overs.
I'm assuming you want to bring this out to differentiate your product with drop height and still retain OEM struts/shocks, as there are no aftermarket ones that are shorter that we can use.
3) Anything farther than a 1.3" front drop will most likely require a front camber adjustment bolt. Probably wouldn't be too hard for you to come up with, if not, H&R and Eibach both make one.
4) Rear, anything more than a 1.2" drop will require a camber/toe kit. None available unless you slot your own sub frame. Would be nice if GTSpec made one specific to the FX. I wouldn't switch from H&R's unless you came out with a rear kit to be able to stay in factory specs. I don't want my tires worn uneven and many of us can't rotate tires due to staggered offset, directional tires, different lip sizes, etc...
Here are my alignment specs with H&R's, 1.3" front and 1.2" rear drop. Obviously differs on all cars, but gives you an idea. I have no uneven wear on my tires:
Alignment Numbers
Actual = (Before, Current):
Left Front Camber
Spec: 0.0 to -1.5
Actual = -1.2, -1.2
Left Front Caster
Spec: 4.5 to 3.0
Actual = 3.8, 3.8
Left Front Toe
Spec: .02 to .1
Actual = .12 (OUT OF SPEC), .07
Right Front Camber
Spec: -1.5 to 0
Actual = -1.2, -1.1
Right Front Caster
Spec: 3.0 to 4.5
Actual = 3.6, 3.6
Right Front Toe
Spec: .1 to .02
Actual = .03, .07
Front Total Toe
Spec: .05 to .21
Actual = .14, .14
Front Total Steer Ahead
Spec: -.05 to .05
Actual = .04, .0
Left Rear Camber
Spec: -.3 to -1.3
Actual = -1.6 (OUT OF SPEC), -1.4 (OUT OF SPEC)
Left Rear Toe
Spec: .09 to .28
Actual = .17, .15
Right Rear Camber
Spec: -1.3 to -.3
Actual = -1.5 (OUT OF SPEC), -1.3
Right Rear Toe
Spec: .28 to .09
Actual = .14, .19
Rear Total Toe
Spec: .19 to .55
Actual = .31, .33
Rear Trust Angle
Spec: (no spec)
Actual = .02, -.02
If you will give a promo price for a tester -- I am here.
---------- Post added at 02:06 PM ---------- Previous post was at 02:02 PM ----------
I think you just explained H&R springs
Okay, H&R drops .1" more in the front.
