green key icon flashing
david
mississippi
Recntly my key icon started flashing many many times after i cranked the car. It is green. Is the battery low?? Seems green would be good and red would be bad :(
also it may be the owners manual but i got mine used and it came without one
Yes, intelligent key battery is low. Same thing just started to happen to mine for the second time in 5 years. Going to buy a battery after work today. It needs one CR2025 battery. To open the iKey fob, take out the physical key. You will see in the opening there is a small rectangular indentation. Use a small screwdriver to pry the key open at that spot. Swap batteries, snap top and bottom parts of the fob back together and place the key back in its slot and that's all there is to it.
