G35 Swaybars to fx45?
cmietzner
Denver, CO USA
When I sold my G35 I took off all the aftermarket parts. Ive looked and have already ruled out my JWT Intake, and my rotors. Does anyone know if my Stillen sways will fit? I looked under the FX and they look similar but before I waste the hour to find out whether they fit or not I figured someone here would know.
Thanks.
Pretty sure they don't fit. Since there are no aftermarket sways for the 35/45 I would have guessed someone would have put on ones from a Z/G if they fit.
They fit WITH modification. They're just short. My original GTSpec bars are G35's, mounting points are the same, they're just all short! FM platform, extended.
Not worth the trouble unless you TIG weld=)
The JWT intake works too, you just need to bore it out to 3.5" and re-drill new MAF tube adapter holes. All not worth the trouble IMO.
Thanks.
^ agree with Ched. I remember Rookie(Viet) getting the g35 gtspec bracing only to find out he had to have them extended for our use. Thanks to some if his pioneering is why we have aftermarket gtspec parts.
