FX45 alarm won't stop
MIKEONE
Mike
And it won't let me start car.... Just cycles and the. If I unlock the car away it goes again and I'm stranded right now. Any help please
Don't know if this will help but once my battery went dead, and mine also didn't want to start.... I had to take the key far away from the fx, lock it and unlock it and for some odd reason that did it.... It's happened 2 times already, but not sure if this is wat ur issue is...
Have you use the actual key to lock/unlock the car? May be the key fob battery is low.
i tried everything, the intelligent keyfob would still lock and unlock the doors, rear hatch etc...took the battery out and it would still cycle...tried opening the door with the actual key...etc...disconnected the negative on the battery for 20 mins or so, and as soon as we touched the terminal back to the battery alarm went off again. Finally we went and got a new battery for the fob and came back after a half hour with the negative disconnected and re-connected the battery...alarm went of right away...hit the buttons on the fob and then it finally stopped...now its acting normal again...would this create a code??
infiniti dealer asked mo to disassemble the FOB which i did, and it still didn't fix it...is it possible the battery was JUST low enough to cause the little transmitter inside the fob to stop yet it still allowed for button functions?
then they said "" just get it towed here" 250 miles ....not a f...ing chance
Is there a fuse in the car that is tied to the alarm you can pull out...at least to get it to stop and then drive?
