fx35
413dan
04 fx35
dan
owner of an 04 fx35.
recently having some issues and came to this site seeking knowledge. I am hoping to view some pictures and hopefully find a wiring schematic for the electrical system as I believe I may have a chaffed or pinched wire.
I am intermittently having an issue with the SLIP and VDC OFF and BRAKE lights being on. Sometimes it is only the SLIP and VDC OFF light and not the brake light.
periodically the brake light sensor button needs to be readjusted so the pedal hits it and shuts the BRAKE light off. I found that out from this site after not being able to get it off. The parking BRAKE light wouldn't go off but in neutral I moved fine so I knew it wasn't engaged. Thinking the movement of wires has cause something in a harness to pinch somewhere.
any thought or inside would be helpful.
its a 2004 fx35 and just turned 70k on the odometer. got it in 2021 w/ 19k on it from the original owner.
thanks
