Fx35
Kacee
Infiniti fx35
Kacee
My name is Kace and I drive a 2007 infiniti fx35. My car has been driven in over a month due to having a wheel bearing replaced. I had that fixed and I went to test drive it. When I cranked the car up it's idling around 2000 rpm . It wasn't doing this before I parked it for that month. Why is it idling like that ? It stays idling the whole time I drive it somewhere.
Welcome to :iS: Kace.
Did the battery drained and you have to jump start it? If so, most likely the car need to relearn since the battery was drained and the settings it saved is now gone. The idle should settle down once you drive it a bit.
