FX35 random vibration at highway speed
dima4855
NM
Greetings,
We just purchased a 2007 Infiniti FX35 AWD with 97k miles on it. The car just received a brand new set of Yokohamas, new Raybestos rotors, new pads and spark plugs, also had the TSB performed for the clicking in the rear driverside axle.
The problem we are having now and have had from day one is when you are on the highway, going between 60-90 and appears to be mostly after the road curves right, after the curve you get a vibration, similar to an out of round tire, the vibration gets progressively worse until you stop the car, let it sit for a couple of minutes and when you start driving again it goes away. The crappy thing is that it's random and I can't always recreate it. We checked all wheel bearing, cv axles, but nothing appears to be wrong. I had my passenger switch seats during the vibration and you can feel it the most when sitting in the rear passenger seat.
I am hoping someone else has had a similar problem and can help me out. Thanks in Advance.
OK, I read the link, but not sure how it pertains to my problem.
Bad brake line is preventing the caliper piston from fully retracting when foot is off the brake pedal, causing overheat and warped rotor, the continuous brake pad pressure against a warped rotor causes vibration when accelerating or cruising.
Sent from my iPad HD
