Fx 35 Owner!! HELP!!
AlejOFx35
Puerto Rico
I'm new to the scene, and I have to say I've learned quite a lot with you guys!!
I have a 35 06' and every time I step on the gas hard I get this noise like thirs a rock or something somewhere stuck!! It makes a Clack Clack!! It's only when I hit the gas hard, otherwhise it doesn't do it! Don't know what it is and it's pretty annoying!!
Is the sound related to engine RPM or is it just two "clacks" when you floor it? Also is it coming from the front or back? If its just the two clacks coming from the back it could be a loose tool in your spare tire compartment. Probably not if it doesnt happen when you hit the brakes.
Mine makes a bit of noise from the engine bay(if its ice cold and I have to give it a lot of throttle get out into traffic or something) but only when its really cold. It almost sounds like detonation but a little more mechanical... Very much related to the engine rpms.
Dr2K, how would the belts relate to the sound?
It comes from the front and it doesn't matter if I have been driving a while or if just started... It always makes it! 2 clacks only!
---------- Post added at 04:48 PM ---------- Previous post was at 04:47 PM ----------
I always run on Premium!
