Fuse problem/question
HanJo Lee
New Jersey
Hello all, I have 05 FX35.
I encountered this problem with the fuse that lights up DTRL, Taillights and interior lights (Clock and console lights).
I had an experience when it completes went out which fuse was blown.
However, tonight it went out thought it was blown again, but it came back on soon after. It's been flickering when engine is off and turned on.
So I know it didn't blow out. I thought the fuse is might not installed properly so I opened up the fuse box (Located behind the battery) and checked the fuse (top left red one 10A) and it was installed correctly.
Just in case I replaced the fuse to a new one.
Does anyone know about this problem? was it the bad fuse or the box itself?
I hope the new fuse works well from now and on since at night if those taillights are out, it is risky to drive because people behind me couldn't see me that well.
One of the drivers actually warned me that my taillights were out.
Could it be a cold weather? (Northern Jersey 28F degrees at night now)
Thanks all in advance :)
Hm... so should I just put back the OEM or OE style bulb back in?
Why would LEDs cause this problem when they consume less voltage than OEMs?
Thank for your help!
