Fuse box
There is one under the drivers dash and two in the the battery compartment (one in front of the battery and a larger one behind it) under the hood.
ok thanks man, I have no idea why my fog lights wont come or my license plate lights, so this is the first place im going to check
fog light fuses are the big fuse box int he engine bay....take off all the plastic above the battery, and behind the battery towards the driver side there will be abig black box; pull up on the plastic to remove the cover, and there will be about 20 fuses in two columns and a bunch of relays. The FOG LIGHT fuses are the 2nd from the bottom on the right coulmn, and the 2nd and third from the botto, on the left side; all 15 amp fuses. Check the one on the right first, since that one usually blows. I'm unsure which is the plate light fuse, but if you go buy a 10$ fuse checker you can just go up and down the rows and check which are blown.
There is also a fuse box under the dash tot he left by the dead pedal which has a bunch of ufses...the plate lights are most likely there.
The fuse box description (that one close to e-brake)
attachment.php
I am having fault similar to the description above. My head lights are on even when the head light switch is off, i removed the switch and it remained on. I notice when i switch from off to auto and other positions on the switch, it doesn't affect the head light as it remains on, while the fog light, windshield wipers and Air conditioner compressor are not all working, although the rear wiper works. I have checked all fuse boxes on the suv, the ones around my battery region and the one under the dash board close to my left foot, all fuses seem ok. Please i really need help.
---------- Post added at 12:08 PM ---------- Previous post was at 12:05 PM ----------
I tested the compressor and wipers by connecting them directly to the battery while the car is on, they all worked, but you all know its not right to connect them directly to the battery.
