fuel sensors and Strange feeling of my 35's steering wheel and
MilkWay
Hi, guys
1) Recently, I found that the steering wheel does feel lighter than before. After a cold start, I drove out of garage which needs a 90 degree turn of the vehicle, I can feel the steering wheel is much lighter to be rotated by me.
I have a 11 FX35, 8000miles on it. Is it normal? What is your opinion?
2) I found my tank only takes around 21.5 gal if add gas from empty and then stop. What is your situation? Did you let dealer change the sensors for you or this is a normal situation
Thanks:rotfl::rotfl::rotfl:
You can never fill the gas tank to it's actual rating. When you go to the gas station, there is still fuel in the car. Even if you run out of gas, there is still fuel in the tank, just not enough for the fuel pickup.
I did check tire. The required pressure is 33, recently is cold, mine is 32 or 31, will this affect the steering wheel much?
Ur tire pressure has nothing to with ur tires being bald (well not for what are talking about). Bald tires is in reference to the amount tread left. Worn down tires can have less grip.
I think its just in your head. P/S fluid cold vs hot might have a small role but nothing an average person can notice.
