So I'd like to upgrade both my diffs to limited slip and have been doing some research. Here's what I found.
FX50 V8 Front Diff without ring+pinion Part Number: 38421AR000
Most AWD infinitis and even the R35 GT-R use the same part number in the front diff, except for the ring+pinion diff ratios.
Easy to find albeit expensive upgrade, R35 GT-R front aftermarket LSD and done.
FX50 V8 Rear Diff without ring+pinion Part Number: 384211CA0A - unique to the V8 VK50VE ??
FX35/7 V6 Rear Diff without ring+pinion Part Number: 384210C00A (2WD) or 384210C50A (AWD)
shared with G35/G37, 350/370Z, Frontier 2.5 and 4.0, Pathfinder, Xterra and others
So, what to do with the rear diff of my FX50? Will the V6 unit fit? If this is the case then an aftermarket 350Z or 370Z LSD will work.
If the V6 unit won't fit then the entire pumpkin may fit or is the rear subframe unique as well? Anyone knows?
