Front struts
Aviator30
Chicago
Ok guys just went for an alignment I'm lowered on h&r s been so for a bit when i got an alignment last month my front left and right camber was 1.2 in spec I had to change both strut bearings went back in for an alignment the left side was put to 1.1 however the passanger side is at 1.6 and they said they can't adjust in to spec on top of that they scratched my f ing wheel. Are both lower strut bolts from the knuckle to strut the same or no maybe I mixed up both bolts on the right side? Not sure if one of those bolts are used for camber adjustment or not
The bolts are the same for both side. There are times I found that I just to loosen all the bolts and re-tighten them, or clean out the holes and bolts with some sand paper, then take it in for alignment seems to cure the problem.
Hope you took advantage of lifetime alignment service at the shops. I know Firestones offer it. You may try to talk to the shop to pay for the different to upgrade to lifetime alignment if they offer it.
I would bargain with them to send out two wheels for refinishing since the you only see two wheels a time anyway, so it would not be so bad visually at the least
