front end noise
angeljr8282
brooklyn
What's guys today I started to get this squeaking sound from the front end when I go to potholes. It sounds like a little mouse the car has 85 k miles. and I haven't done any suspension work on it could be some bad bushing
Heres a list of things to check
Fronts struts failing
Strut bearings
Sway bar bushing also check to see if this is loose maybe a loose nut.
Tie rod bushing
Lower control arm ball joint
