Foot Well Lighting. HELP!
addison012
Texas
Hello all,
I tried replacing the 168 bulbs located below the passenger and driver foot wells. When replacing one of the bulbs, both lights completely shut off. I tried plugging in replacement bulbs and no luck. I have verified every fuse in front of the battery and driver side and there are no bad fuses. There are no other outages in lighting/electrical that I can find, everything is functioning properly as far as I can tell. What can be the issue, any recommendations?
Thanks in advance,
Matt
If you're sure the fuses are good, didn't reverse the leds and have tried increasing the brightness via dash buttons, then take a volt meter and check receptacle/plug.
TapaTalkin'
Interesting how I post about footwell lights awhile back, 87 people view it and nobody responds... then you write a post and get an instant response... I don't understand this site! Grrr!
