I posted about this in another thread, but figured I would start a separate thread for anyone else who might have this problem in the future and to hopefully get some more insight from members.
My engine has been sputtering while at idle for a few months now. I figured it was because my car is running lean, but not 100% sure on that. The engine mods I had on the car when I first noticed the problem were: Kinetix V+ plenum, LMS intake tube with Stillen CAI, Throttle body spacer, and HKS exhaust with Kakumai Y-Pipe. I took off the throttle body spacer because I read they tend to make our cars run lean, and also took off the LMS tube for good measure. Removing these pieces did not resolve the issue.
I just did the ECU reset, accelerator position learning, throttle valve position learning, and idle air volume learning and the puttering at idle did not go away. I recorded a video below of the puttering while at idle I am talking about. The first time it dips down is at the 10 second mark and then jumps back up at the 14 second mark, then dips down again at 40 seconds and back up at 44 seconds. It is kind of hard to notice in the video, but every time it dips down it makes a sputtering noise and the whole car starts to vibrate a little bit until the idle levels itself again and the sputtering stops. Sometimes it is more extreme than others. Does anyone have any insight on what might be causing this, there is no CEL on.
https://www.youtube.com/watch?v=1nkC6rH-T2w&feature=plcp
