I agree partly with the "myth". Harsh detergents and solvents shouldn't be put through an engine to remove oil; it could damage seals and it strips all lubrication. However, the solution to black sludge isn't "accept it and leave it, because flushing could clog something".
The first point is to change oil regularly, hopefully with synthetic oil since it's more refined. Sludge primarily precipitates from less-stable oils in overheating engines. Don't use additives, since they're not stable.
A "flushing oil" can help. Instead of a cleanser to flush the oil, they temporarily use extremely light oil as a solvent. It removes the last of the old oil, and a lot of gunk with it. Some might say that letting as much of the old oil out as possible is better, but they should witness filthy flushing oil coming out after that.
Many people use Seafoam brand light oil. I wouldn't use it as a daily additive, but adding it on the way to an oil change can make the oil less viscous to drain better. I've seen it work beautifully as a gasoline additive; it cleaned out a combustion chamber that was filled with carbon and some difficult slime from a bad seal that dissolved.
It's academic, mostly. Avoid fancy tricks when you're uncertain. Just change the oil regularly, use the right weight for the climate, use the best oil you can, and change the oil filter every time.
