ECU / Airbag Reset - Accelerator / Throttle / Idle Learning
fxlr8
Staff
Administrator
Not exactly sure on the origins of the following procedures...(All procedures below were found at various unknown online resources).
ECU Resetting Procedure
1. Confirm that accelerator pedal is fully released, turn ignition switch "ON" and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to "OFF" position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps.
Accelerator Pedal Release Position Learning
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch "ON" and wait at least 2 seconds.
3. Turn ignition switch "OFF" wait at least 10 seconds.
4. Turn ignition switch "ON" and wait at least 2 seconds.
5. Turn ignition switch "OFF" wait at least 10 seconds.
Throttle Valve Closed Position Learning
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is "ON".
3. Turn ignition switch is "OFF" wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
Operation Procedures
1. Perform Accelerator Pedal Released Position Learning.
2. Perform Throttle Valve Closed Position Learning.
3. Start engine and warm it up to normal operating temperature. (EDIT: DRIVE YOUR VEHICLE FOR AT LEAST 5 MINUTES FOR PROPER OPERATING TEMPS)
4. Turn ignition switch "OFF" and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch "ON" and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle. (EDIT: START YOUR VEHICLE WITHIN THE 3 SECONDS OF STEP 9).
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Airbag SRS Light Reset.
1. Turn ignition switch to the "ON" position (Do not start the vehicle).
2. All cluster lights will come on (Diagnostic Mode).
3. As soon as the Airbag light turns off, switch the car off. (Be sure to turn the ignition switch off before the airbag light starts flashing).
4. Repeat steps 1-3 (2) more times and the flashing light should stay off.
