DS manual mode slow shifting
Ashephillis
2009 FX50S
ASHE
2009 fx50s. When I use manual mode in DS there is probably a 2 second delay when i change gears with the paddles at WOT. Does anyone else have this problem. I never use them because of this reason. Light throttle they seem to shift ok, but gear changes are painfully slow when i try to get on it. Thoughts?
Almost seems as the ecu is cutting power to avoid hitting the limiter or something like that.
I don't have this issue. I would not say the trans is fast by any means but it does not take 2 seconds to shift. is this a new issue or has it always been this way?
Sounds like your car needs a flash update on the tranny , TSBs at no charge as long as your car still under warranty. On other hand as least here in US dealers you can always try to negotiate the price.
http://www.infiniti-techinfo.com/TSB/TSB_xml/nmIndex.aspx?tsbType=TSB
You can go to this site and check for tsb's of your car model/year and just show it to your service consultant when you take it to the dealership or contact them
