DRL instead of turn signal ( V3 tritom system)
George
I wanted to install V3 TRITON 5K WHITE AMBER TYPE 2 SWITCHBACK LED TURN SIGNALS, but manufacterer tell me, that it won't work of Infiniti:disapointed:
here is his answer:
"Switchback will not work in that car. You would need to stay with all amber. Your front turn/park is a 7440 single element bulb."
The question is, is it possible to change the bulb in order that would this system work? and what is the actual problem (pin configuration)?
simmular as V3 triton we/ve got in Russiaa, but we don't know what bulbs and what led's they use. ( price is 11 000 Rub or 360$ with installation)
[video=youtube_share;-lq0Sdj6prw]http://youtu.be/-lq0Sdj6prw[/video]
Switchback will work with some modification. Does the switch back come with a separate power wire dangling from the socket ? If so you can just tap this into the dtrl.
sent
Exactly, my thought. It has to be custom wired as long as they provide the pin out of their connector or pigtail connector. Just make sure they provide the proper socket to fit our housing. Last I contacted them, these bulbs was pre-order; not available until end of March.
In april i will install V3 system.
Today they give me an answer:
"Problem is your SOCKET is a single element, our switchbacks require dual element. Approximate date 3/31/2013"
Ask them if their bulb has a pigtail like lafx mentioned. The ijdmtoy switchback does if u want to see for reference
sent
I placed an order on the V3-Triton 6000K switch back bulbs last night. :smile (2):
