Driver side xenon headlight is not working
niconyfx35
New york
I have replaced the bulb but the xenon light is still not working, please reply if anyone had the same problem and what did you do to fix it. Thanks in advance
Knowing HID's, I'd say it's either the ballast or a fuse. Check the fuse for the headlight first. If it's not that then it's a ballast problem.
Would you know where is the fuse for the headlights I can't find it. If it's fuse I can change it, but if it's ballast I have never changed ballast and is this something that can be done easily or should I go to mechanic for it. Also if it's ballast do you know which and where is located. Thanks for reply I really appreciate it.
Ballast for headlight is located on the headlight itself right underneath it.Check other forums for the diagram im pretty sure you can find a chart with the fuse if not it should be in your handbook.3 things to check...Fuse,Ballast,and Bulb to make sure its not blown.
