Dot-matrix telling me Battery Empty
JohnnyFX
Vaudreuil-Dorion Montreal
2012 FX35
Hi guys tried searching for this but came up with nothing.... I did replace the key fob battery with CR2032 and still the matrix tells me the battery is almost empty...mind you the car starts.. its just annoying that it does this...also there is not flashing lights where the key fob goes in... has anyone seen this happen before...the FX is still under warranty....
Mine does it when I get out of the car and leave the car running, but if I leave the key inside the car it is fine, I think this is normal. Do you mean your matrix still shows low battery even when you have the key inside the car and it's running?
I don't have another I need to get a spare soon.... BUtttttttt I think i might have found the culprit maybe....
so if i turn off my bluetooth on my phone I have a One+One phone..... and I when i get in start the car it did not do this so i went for a ride around the block
got back home got out of the car went in to my garage and went back to my car and tried again and it didn't do it...WOW thats strange it would always do it on a second start
could it be my bluetooth on my phone doing this....I think so... what do you think....I think it might use the same freqency....?
>>>Update just tried again and it's not doing it anymore.....WOW my phone is on the same frequency as the key fob ....
so this means i turn on my bluetooth only after i start the car....WOW...
Weird, but that's good you found the cause.
You should have received two Key Fobs if you bought your FX from an Infiniti Dealer. I have always been given two with every car I have purchased.
