Door wiring question
david
mississippi
Ok I was opening my second door for door lock actuator replacement. Long story short one of the wire clips came open and the wires came out. I need to know which wire goes in which slot
The wire clip in question only has two wires white and black. It has three slots. It goes under the door controls on the same portion as the huge wiring harness that has tons of wires
this is where I put the wires but I'm trying to find out if its correct before plugging it up
---------- Post added at 09:53 PM ---------- Previous post was at 09:51 PM ----------
It goes on this piece to the lower left
---------- Post added 05-15-2013 at 12:08 AM ---------- Previous post was 05-14-2013 at 09:53 PM ----------
Those wires provide the power to the entire assembly I gather. I checked windows and they all worked but after I put the door panel back on they aren't working. Maybe a wire came loose? This is frustrating. Way harder than coilovers install
Since it came off connector in the beginning, sure sounded like it came off after the door being put back since you tested it and everything works.
I hope so. Ill take the panel off again tonight after work and try to figure it out. The switches aren't lit up and none of them work. I look at fuses as well but could figure out a problem there.
