In general you can tint the windows without removing the seal or glass. I have try to tint with removing the glass complete off the door. I find is a bit easier, but you spend the time in removing and reinstalling the glass back.
Anyhow, to remove the door pannel:
1) Grap the aluminnum cover on the door panel and pull it outward, undo the two bolts (top & bottom on the handle.
2) Pry open the little square cap on the door panel, undo the screw.
3) Start the lower bottom corner of the panel near the hinge and pull it outward toward you to release the pressure clips.
4) The glass is held on by two screw that can be accessed via the access holes in the door (may need to remove the door speaker for easier access to one of the bolt).
5) Before disconnect the wire to the window controller, align the two bolts that held the glass in place with the access holes on the door skeletal.
6) Disconnect all wiring and remove the door panel.
7) start wiggle the glass up and out of the door.
