does anyone have any idea where I can find the radio code trying to activate xm/sirri
should also be on the xm receiver, which should be located behind the rear seat in the cabin... are you sure you even have a receiver?
I just set mine up recently. When you set the source to Sat, the words "radio code" and the actual radio code alternate on the main screen. The only time the code info stops is when the signal is received. I also had to tune to check 184 and call the Sirius reset #.
Sent from my DROID RAZR
I mostly listen to CDs, was fooling around with the radio, pressed the SAT button and CH1 came on, so I turned the right knob and other channels came up. Flipping thru the channels until I got to CH100 then the radio ID came up and went back to CH1. (I had a trial run, but that ran out 4 months ago because all I got was CH1)
This may sound crazy, I saw this on a site, (maybe ask.com?) If you have unhooked or changed your battery, press the SAT button and do nothing for about 10-15 minutes and hope the radio resets......
or maybe you don't a SAT radio. Good luck! (I'm trying to help a brother out)
