carguy75
- alpharetta,ga
Hi. My FX seems to lose about 1-2 quarts of oil between oil changes. My FX do not smoke, but oil seems to disappear. I heard that this is a common problem with the older VK engines. I use Castrol Syntech 5W-30 oil. I read in the FSM that 10W-30 or 10W-40 can be used in warmer areas. I read on the Castrol Edge spec sheet that 5W-40 is thicker than 5W-30, but lighter than 10W-40. I was thinking about changing over to it, but want to know if someone else is using 5W-40 already and if they lost MPG and power by using it. If I use 5W-40 and my oil consumption decrease or cease all together, than maybe the older FX's should be running a thicker oil from the beginning. Maybe the 5W-30 is used more for obtaining optimal fuel economy at the expense of using the best weight of oil for the most engine protection and that is why Infiniti states in the FSM that the heavier weights are acceptable for hot weather climates.
