hows it going guys? I recently purchased a used fx35 2003 with 121000 miles. I went for a drive earlier and noticed that the temperature was climbing radically, well it looks like the water pump is going out. The temperature is fine when im accelerating, however when I take my foot off the gas the temperature sky rockets. Anyone else have this issue before???
Without being able to see the car, my all-in bet is on a failed thermostat.
Since you're at 121,000 miles, depending on if you want to be proactive (unless these items truly did fail), these are the items I just changed (even though none of these have failed on my car at 135,000 miles). The last thing I want is to be stranded on a road trip:
1) New thermostat. Get OEM, FX35 open at 170 F degrees, while the FX45 opens at 180 F degrees (fun fact for the day).
2) New coolant hoses (cheap, might as well). Sometimes these crack and start to go bad.
3) New coolant (kind of a given).
4) Spray clean the radiator correctly, a shop should be able to do this if you are unfamiliar. A lot of debris will be caught in there.
5) Water pump and gasket.
6) new belts if you haven't already.
7) new radiator cap (you can try a NISMO one if you want or just go oem).
