Custom dueal headlight wiring HELP!
So did you ever finish this project? I decided to do a quad projector, not to the extent of turbocad's though. I've ordered one of the aftermarket projector kits and am waiting for it to get here. But it looks like since I don't need the motorized levelling system, I won't need nearly as much room. With initial measurements, I think I can get away with just enlarging the DTRL bulb hole some to sit the projector far back enough and then putting a cap back there to seal out moisture. Then the plan is to update the shrouds some. I've got an idea for LED's as well for the turn signal, we'll just see if I can remember how to bend acrylic correctly.
um im like 90% done. I have one side done 100%. i just need to repaint the bezel for the other side and put it all together then clean both lenses.
Finally finished! got off work early today and decided to sand, clear coat and INSTALL the headlights!!! looks amazing! hopefuly enough light out to take some pics
