- Nashville, TN
- 2011 FX35 AWD
So I just got home from a long weekend trip down to Georgia. Pulled in to the driveway, turned off the car and finished a conversation my gf and I were having for a couple minutes. We finish, I go to hit the cargo hatch release and nothing happens. I try it on my key fob and nothing either.
Then I notice my running lights and fog lights are all on and my passenger headlight is on... but not the drivers. I make sure the lights are off on the turn signal and then try to restart my car. Nothing. Outside lights all still on. It doesn't cycle though ACC or ON at all and then finally does and is really lagging and makes some clicking noises. I put my keyfob in to the slot and the pull key out display lights up in the driver light cluster. I put it back in and lights start flashing where you put the key in. I try to cycle the start button again and nothing inside lights up except the emergency brake light, the seatbelt light, and the battery light. Then a few seconds later, the airbag light comes on and flashes. The car won't start still and the light on the start button stays as "ON." I have to hold the button down for everything to "turn off." The doors lock with the fob, but not the door.
I tried disconnecting the negative terminal for a minute. Well, that fixed the running/fog/passenger lights being on. Doors unlock on the car at first. Not starting still, but the center console now starts lighting up with the other lights and it throws the same lights on the drivers cluster.
I tried searching the forum for some answers, but I haven't seen anything with this list of crazy. Does any of this make sense to anyone, or familiar? Any questions or clarifications needed? Thanks!
