crawford plenum capped(??)
sch4400
Los Angeles
I bought a used crawford plenum.
seller said : the water lines need to be capped.
I don't know how to buy it.
please advice. where to buy, how to buy ...also size.
""seller said : This was used on a Nissan 350Z race car so there are no provisions for water heating. The stock plenum is heated by engine water. This plenum does not have provisions to do that so the water lines need to be capped.""
maybe I need something in circle. here's picture.
file_down.asp
http://www.crawfordz.com/pics/castplenum-1-tmb.jpg
this is used plenum pictures.
file_down.asp
Hmm... aren't there like little nipple thingy to connect the hoses on a normal plenum?
Korean Spam on the link provided :tongue: - I'm a fellow Korean as well (not a Mongolian!)
Good luck
They are talking about the coolant lines that connect in the back by the throttle body. You just need to buy a small connector and connect the two coolant lines together since the plenum doesn't have connections. It will make more sense once you remove your plenum
if you want to completely bypass the line you can get the connector at home depot, look for something like this ///6311&highlight=coolant+bypass%5C
otherwise you can get frankiago's thingamajig.
