Coolant levels dropping
themadnewfie
2009 FX35
Brian
Hey Guys,
So what i first thought was a random fluid drop .. is now consistent
So 2 weeks back i noticed that the coolant leveks were below min (almost out of sight actually)
I went ahead and filled it up to the max levels and commited to looking at it over the next couple weeks to ensure nothing funky is going on
I sit here now and its half way between max and min ... so a good bit has dropped
The fx is parked in the same spot in the garage each night and i cant find any noticeable spots or drops on the floor
So .. where is the coolant going ..
Please help
Is there any white smoke coming out from your exhaust? Or any signs of coolant in your oil? These would be signs of a head gasket issue.
Open your oil filler cap. If it is milky and chocolate like in the cap then you have coolant leaking. My radiator was busted and i never knew it was because when it leaks it just hangs around in the bottom part of the bumper. If you see none of these, you may have a head gasket issue like 415cpa said. I would have your cooling system pressure checked first and go from there.
