Coilovers that retain oem ride height
FXStorm
Denver Colorado
2010 FX50S
I'm in search of coilovers that retain oem ride height. Does Anything like this exist-otherwise I'll just get new oem ones. I need to retain the height for winters with deep snow in the mountain trails ect. Thanks guys~
"Infinite Patience Produces Immediate Results."
Most installing coilovers will use it for lowering the ride height to their liking, that doesn't necessary mean that you can't use it to set it to factory ride height. You can set any of the coilovers to any height you want.
Andy is right. If it is time to replace you struts and/or springs I can't see why you wouldn't go with coils because 1) if you choose not to lower its good to know you have the ability to when you want 2) less$$$ 3) better ride quality . You really have nothing to lose IMO. I will need to replace my struts soon and living in SoCal winter isnt an issue for me so BC coils with a slight drop will be just right. other brands are out there as well like Megan Racing, D2 and a couple more.
Thanks guys I called Megan and they told me their kit is lower than stock at full ride height I'm going to call a couple other manufacturers and see what they have to say about theirs. Ideally I would like to get coilovers for all the reasons listed above, mainly for ride quality. I'll keep you all posted and let you know what I find!
umm when i had megans they were actually taller than stock height
Was it for the first gen by chance? I've read those were in fact taller, one member even lifted his FX 1-2" with them for fun to see how it would look. For what ever reason I'm guessing that has changed for the 2nd gen ones.
who shoot on your thead title it shows fx35 03-08, yes for the first generation ones. I havent had experience with the 2nd. But i think you will be fine keeping it close to stock height. Dont stress over it too much
Hahaha, Peter beat me to it. As I recall, there was one member from Europe disappointed with his ride after having H&R springs installed. He was after more floaty boaty rather than the more controlled and sporty that most of us is trying to achive with after market springs
I'm also looking to keep the ride height, but reason is to avoid camber problems while getting a better ride. I know Megans will reduce the height by at least half inch. I've emailed BC to find out if theirs is any different although I doubt it given they are pretty much identical to Megans. Any other options?
The word "better" is highly subjective. Some like plush some like sporty.
I've driven cars with horrible worn suspension and steering all loose, but the owner said nothing is wrong and drove my car and said it was way too stiff.
its just the stock springs ride a bit harsh. the coils and/or springs eliminate the harshness and also provide a huge difference in handling and also minimize body roll. so my point is that the stock springs suck... thats the only way to put it.
Coilovers have a much higher spring rate than stock, they also have a higher spring rate than H&R's I believe. So the ride is going to be firmer, there's no way around that. The only ride advantage of coilovers is that the damping is adjustable. We all complain about the OEM ride mostly because it is way underdamped which leads to the bouncing, floating, "harshness" that people complain about. When I had OEM springs, the ride always felt unsettled. It was soft, but then over rough roads, it would feel a little uncontrolled with lots of bouncing. Swapping to H&R's helped with the floating feeling as the spring rate was higher so it controlled movement a little better at the expense of rougher ride over small.
Coilovers have a higher spring rate but also higher damping so it "should" be better matched. The ride is going to be worse over small bumps but over big dips I personally think it handles better as there isn't the floating feeling you get from OEM. I have BCs and I've run the original spring rates and currently have higher rate BC springs installed. Anyone who tells you that it rides better than OEM in all instances is lying, it can't. It's just that the damping is better matched to the springs so overall it handles better and rides better in some instances.
If they made better shocks and you could match them to your OEM springs, it would probably ride better than coils. FWIW, coilovers aren't designed for optimum handling on our cars or really any cars. They're designed to fit your car using off the shelf parts. The only custom part of the coilover is the shock mounts and top hats. The important stuff is standard, they just pick a spring rate that's close enough and the shock has enough adjustment to work. The coilover options we have aren't at the price points where they would do specific valving for our cars.
I don't think my BCs ride so great, the H&R were better. the only thing coils have going for them is more slammage
BC also rust up and seize in winter conditions :bad:
I emailed BC regarding ride height and this is what I got:
Due to the nature of the item, they are not designed to reach factory ride height. These coilovers will drop 2-3 inches at the least. --
Sam Lau
Enjuku Racing Parts, LLC
Sam Lau
Unless you're driving through 3 feet of snow at all times, I am sure you can afford to lose 1" of space. I doubt it's 2-3" at least of drop on highest setting.
My only concern with lowering at any amount is the camber issues, otherwise I'd love to get the BC coils. The sport tires are not cheap.
