CNT Racing HFC
dragonh
Taiwan
2005 FX35 AWD
Hi all Is anyone running the CNT Racing HFC's on their FX and will they fit with the invidia full cat back exhaust?
Any opinion or suggestions, Pls let me know...tks
All HFCs or test pipes will fit the Invidia. Invidia exhaust is OEM replacement so it bolts to your factory cats. Aftermarket HFCs and test pipes are designed to fit in the OEM location so they will all work. CNTs should work fine, only negative I've ever heard is that they're louder than some other brands because the material is thinner. But the same has been said about Kinetix.
Only exception for AWD is going to be Motordyne ART pipes or ARK test pipes because the branch resonator won't clear the transfer case.
