I recently had to replace the heater core in my wife's over have fx35. What a son of a bitch! :at-wits-end::at-wits-end:
Prior to disconnecting the steering column shaft at the coupler, I marked it in multiple locations to ensure that I get it back in the same position. When I was trying to reassemble it, I had problems getting it to line up and got frustrated and grabbed the steering wheel and spun it so that it spun multiple times. In doing so, I now realize that I screwed up the clock spring inside the column. I am about to buy a new one to replace it.
Does anyone know if I also damaged the steering sensor or do I install the clock spring and then have that code cleared and just see? My slip and vdc lights come on as soon as i move the steering wheel so i know that it is at least off, just dont know if its dead.
Also, if i got a used clock spring, then how do i know "where" it is in its zero plus/minus three turns position?
I surely hope that someone can help me out. Thanks so much for all the help that you guys give here.
Rob in Houston
Rob in Houston
