Clicking Noise From Rear Axles
  • Start date Start date
F
Fire0nic3
Guest
ITB08018
  • IF YOU CONFIRM: A "clicking" noise is coming from the left and/or right rear axle (driveshaft) when accelerating from a stop, NOTE: If any other types of noise are observed or heard under other conditions this bulletin does not apply. Consult your Asist service information for any other issue. ACTION: Remove both left and right driveshafts, clean the flange surface of the outer joints on the driveshafts and apply a specific amount of Molykote M77 grease. Refer to the Service Procedure in this bulletin for details. NOTE: This is the only approved service procedure to repair this incident.
Never had this issue either. If anyone on here does bring it to the dealer :wink:
Does anyone have access to the service procedure for this? I have the grease now I just need to know where to put it. I can see above that it needs to go on the flange surface of the outer joint but before I take everything apart I would like to know exactly what that means.
Thanks
