clearance light
Sancho
Boston
I am about to cahnge my fog lights to and hid kit to match my headlights. (the factory color) I also want to change my clearance lights under the front turn signals to match my headlight and fog lights. Does anyone know if its going to require another hid kit or is there a good quality bulb that will match that I can use?
If your changing the foglights to HID, then yes you will need a whole HID to change those. To match the factory headlights you need 4300K colored H8 HID kit
For the clearance lights below the turn signal I think you mean city lights. Those use a 194 type wedged based bulb. To get those to match you need to use a 5000K colored LED bulb.
Ok cool. I've been looking at the lights and I think Im gonna go 6000k with the fogs. So doing that I should also go 6000k with the headlights and would I go with the 6000k for the city light?
How do you get access to the city lights on a 2nd gen? Did a forum search, but didn't find much. Also can't find anything in service manuals, but the owner's manual calls them clearance lights.
