aquilles10
- Los Angeles
- 2018 QX60
My 04 FX35 was having problems starting when cold due to a dirty throttle body. So I followed the instruction on this board and the cold start problem has gone away. However, I've had new problems emerge since the throttle body cleaning. For one the annoying Service Engine light is always on. Then the idle is high so I've tried to do the pedal dance to reset the check engine light and adjust the idle. I successfully turn off the service light, but the check engine light keeps coming back on and the idle remains high (around 1.2k RPMS at start up and 750 at warm idle).
But now something more annoying has developed. There is a strange sound coming from the front of the engine. It sounds almost diesel like (ta-ta-ta-ta-ta). It comes and goes and I can hear it on the freeway when I am just cruising at a steady speed. As soon as I step on the brake gradually, the sound immediately goes away. Then it eventually comes back. It's almost light a light mechanical knocking sound and I think it's coming from the pulley area. What could this be? And could it be related to the Service Engine Light?
