Check Engine Light
SMac
cincinnati, OH
sherry
Hello
I am new to this site, but have a 2003 Infinity FX35 that had an issue and need some advice. I was driving home and all of the sudden multiple lights came on (brake, check engine, oil I think, etc). The power steering in the car went out as well. I was able to pull it into a driveway and turn it off. I waited a few minutes and got it started again without any lights or problems. Since I was 5 minutes from home, I drove it home. Just wondering if anyone has experienced this issue and what I should check. Thinking I will check all the fluids in the morning (power steering, oil, etc.). Any advice is appreciated.
Thanks
Yes check all your fluid levels for a start our FX's can be very sensitive to low fluid levels.
If it happens again have your codes pulled to see if anything shows up there.
My check engine light came on and i was searching reasons and i tried just tightening the gas cap properly and the check engine light turned off its wierd but it worked
